C17LoadSmasher
- Joined
- Nov 24, 2001
- 152
Hey all...<br /><br />It could be just me hearing things.. but, here goes. I decided to change the lower unit gear oil today. I went and got the pump and the proper oil and went about draining it and then pumped it back full until it was to the top of the vent like I am supposed to, etc. Well, I also was going to change the motor oil today, so I went to a nearby lake to fire it up and cruise around for about 10 minutes or so to get it up to normal operating temperature, and then I would drain the oil. Well I fired it up, and it could be me, but it sounded funny. This is after I changed the lower unit oil. I figured it could just be that it sounded different (was a shallow water slip) so I took it off the trailer and ran it around for a few minutes and it didn't seem to make any abnormal noises. I should note however, that several weeks ago, the bilge got filled with water when one of the cooling drain hoses popped off and pumped raw water into the bilge. I don't know if this might have anything to do with it? Could air in the lower unit cause the noise? Any suggestions would be a tremendous help. Thanks a lot.
