1985 Mercury Black Max 150: Two things, 1st alarm sounds (steady beeping) after I was on lake. I turned off the master ON/OFF switch and it turned off the alarm. 2nd after trolling (idle seed) for 15 min went to go full throttle and wont take throttle past 2250 rpm without dieing. went through this trying over and over and am able to get the rpms to 3k then it will clear out and move out at 6000 rpms nicely. As long as I keep the rpms above 2500 I can throttle were ever I want. Let it go below or stop and take off, will probably do it again.
