Hi all,
I was out boating today. All was well and then I looked at the clock. I needed to pick up the pace. I started to push towards WOT. After about 10 seconds, the alarm sounded. I backed down to idle and It quit. The alarm sounds for three things that I am aware of: 1... Oil pressure, 2... Temperature, 3.... Low outdrive oil.
My gauges were all in spec and I even shut it down to check and add a little engine oil. I continued to investigate by moving through the rpm range and the alarm kept sounding after a few seconds in the 4500 range and would not quit until I slowed to almost idle. It even seemed to start to sound closer to the 4000 range on my last attempts but by then I was at the launch and had no more time to mess with it.
So, does anyone have any theories? I don't know where to start!!!
This is a 2002 Chaparral 265 SSI with a 496MAG Bravo 3.
Thanks for any help!
