SuperNova
- Joined
- Mar 16, 2007
- 1,455
I took out my little Checkmate for it's first run this weekend and it ran fine for the first 20 minutes, but then I started getting a steady beeping from the alarm horn after the engine was started. One beep every second or so. Checked both the oil resevoirs and they're both about 3/4 full. I let the engine sit and cool off for about an hour and it started beeping again as soon as it was started. The initial 3 or 4 beeps when you first turn the key on are still happening normally. The water tell-tale is putting out a good flow and it's not overly hot water, about what I would expect temp -wise. I turned the key on and turned the engine over enough to get the alarm to start, which it did, without starting the engine and the alarm just kept sounding until the key was turned off. Also the alarm doesn't sound just with the key on until you start or try to start the engine. It seems like it needs to see a certain amount of RPM to start the alarm beeping, but once it starts, the engine could not be running and as long as the key is on it will keeep beeping. I did pull the cap off the engine mounted resevoir and checked the level sensor, it slid up and down freely and I couldn't make the alarm turn off. Any thoughts are appreciated. Thanks in advance.
Stan
Stan
