Gerhard Peters
- Joined
- Aug 13, 2019
- 90
I have my 4.3 rebuild engine back in the boat (as per previous post with other issues) and running. I bought the boat with a none winterized cracked block engine that was seized up. So I don't know about any of the other conditions prior to me buying the boat because I never had it running
When I turn on the ignition switch I hear the alarm sound and the starter will not engage when I turn the ignition switch to start the engine. It is not the relay solenoid nor the starter solenoid. The starter solenoid was seized up but I replaced that with a new one while I had the engine out. I can start the engine by jumping the terminals at the relay solenoid.
I did a test for continuity on the yellow/red wire going from the ignition switch to the relay solenoid. There is no continuity so it is some kind of wiring issue. So far I have not found any other wiring issues.
Two questions:
1 - Now when I turn on the ignition and jump-start the engine at the relay the alarm stays on continually (even when I just have the ignition on). Why is that? What is the purpose of the alarm?
2- I have briefly spent some time under the dash looking at the wiring but have not taken anything apart. Where should I start if I have no continuity in the yellow/red wire?
Two questions:
