Re: alarm (whistle sound)
If you have a remote oil tank, this tank feeds to a smaller tank on the engine, check the cap on the smaller tank. What happens there is a float on this cap and when the oil is two low the alarm sounds. With engine off, unscrew cap, turn ingnition to the on position and see if alarm sounds when you move the float up or down. This tank holds enough oil to run the engine for about 30 minutes without doing any damage. The cap may have a crack in it, if it does this allows air into the system and it will not fill up with oil to the full mark. Do not remove cap with engine running - you will have oil all over the place. At least this is the way a Merc 200 OB works.
