Albemarle 24 - EFI maps and fuel return
firstrodeo
(First, apologies for the cross-post with thehulltruth - so busy there, its hard to get attention)
The quadrajet carb on the GM 5.7 liter in our '86 Albe needs a rebuild. Looking at the Holley Sniper drop-in replacement. Seems doable and reasonable in cost, but I have 2 questions:
1. Has anyone successfully plumbed a return line to the Albe tank without removal, etc.? I'm not even sure there's a sender unit we can remove and operate on.
2. Does anyone have a good (and safe) map for the Sniper quadrajet TB that will work with this engine? My thought is we'd run open-loop, at least initially.
first, welcome aboard
second, OEM engine installations do not return fuel back to the main tank. they have an engine mounted fuel module. I would suggest you set up something like this.
firstrodeo
Scott - thanks!
Great to be here...
Yes, I know there's no return with the current setup. That's why I was asking if anyone else has done this already (installed a return) and without tank removal + surgery - that's a non-starter.
When you say, "set up something like this", what were you referring to?
Thanks again.
If the current tank does not have a fitting which can be used for the return, can install a Tee fitting on the fill hose.
https://www.hardin-marine.com/p-16582-fuel-line-return-to-tank-adapter.aspx
They also make a fitting which you drill a 1/2 inch hole in the fuel tank and then install fitting. The fitting flares it on the inside so no leaks.
Use a hand drill or a fan blowing a lot of air when drilling. The steel bit will not spark on an aluminum tank the the drill will be sparking on the brushes
https://www.performanceonline.com/fuel-tank-return-line-bung-kit-universal/
matt167
Keep in mind that the Holley Sniper IS USCG rated, but also that a wide band oxygen sensor needed for self learning will not survive.. Holley's software will have a tune close enough to make it run, but you will never dial it in
firstrodeo
Assuming I can find a spacer block with an O2 sensor port to install under the riser elbow, won't the sensor last long enough to get a reasonable tune? When it dies, it's an easy swap, right?
matt167
The spacer block ( you can drill a spark plug anti fouler fwiw ) will help the oxygen sensor live, but it's also going to skew the reading into being leaner than it should be . Your talking about sensors that are north of $50 being wide band
I personally would spend the $40 on a rebuild kit vs $1500 for a complete sniper kit
firstrodeo
Been traveling, finally got out to boat today.
Opened deck plate to look at fuel tank pickup/sender area. Saw this:
Left is fuel line. It goes from here to filter/water-separator, then mechanical pump on engine block, then quadrajet.
On the right looks to be an extra port welded into the tank? With a plug in it? I'm going to call Albemarle on Monday to verify, but if what I am thinking is right, I may have a good fuel return option.
firstrodeo
As for spacer block to mount the sensor, this looks right:
https://www.ebay.com/itm/322489476520
As for the mounting angle thing - if the O2 sensor tapped hole is pointed toward the bow, I think the sensor tip will be angled downward most of the time, so liquid should not accumulate.
