Re: Alfa one: no liking, but oil desappears
If you just filled it, then it is possible that while running it burped out an air bubble trapped in the drive.. That is normal, just top off again. Do you have a remote resevoir? If the level is down quite a lot, then it may be something more.. <br /><br />Just because there's no puddle in the driveway doesn't mean it's not leaking.. It could be a pressure or motion induced leak, that dries up once you pull it out of the water.. <br /><br />Scott..
