Mike_Maranto
- Joined
- Apr 13, 2006
- 48
Crownline 21ccr 94 Mercruiser 5.0 with alpha 1 gen2, I need to properly align the engine, the aligment tool goes into the coupler with little force, used the grease on tool and found less grease on top and more at bottom, by reading the threads it seems that engine needs to be dropped from front if less grease on top(correct me if I am wrong), now few question on proper procedure:
(sorry if I ask stupid questions)
1) Should I loose the rear engine mounts bolts a bit before I drop the engine down from front.
2) How to drop the engine from front mounts, (step by step), is there a lock that holds the nut on which the engine sits. There are 2 nuts, one at top and the other one at bottom.
3) The thread on front engine mounts had rust when I bought the boat I wire brused it clean, then ragged the thread with some oil, any precautions I should be taking?
4) does any one know the size of front mount nut, non of my wrenches fitted the nut,(the socket that fitted the top nut was may be 29mm, the bottom should be the same size? I used the socket to get an idea of nut size; should I use an adjustable wrench to adjust, please guide me through
Many Thanks.
Many Thanks.
