Re: all 6 plugs black oily sooth plugs
couple of questions:<br />new gas or old?<br /><br />NEW GAS<br /><br />was it put up with fuek in the carbs?<br />maybe you just got some bad gas<br /><br />GAS WAS DRAINED<br /><br />possible that all of the floats are stuck but not terribly likely.<br /><br />FLOATS WORK CAUSE NO GAS LEAK AND THE PRIMER BULB GETS HARD<br /><br />how did you mix your fuel? may it is just too much oil.<br /><br />I JUST POURED OIL FIRST INTO THE DECK FILL TUBE AND THEN THE GAS FROM A 5 GALLON CONTAINER<br /><br />perhaps you can borrow or mix up a new tank and try again.<br /><br />I HAVE THIS ALSO PROBALLY WILL TRY, ITS A 6 GALLON TANK THAT I KEEP FOR THE BACK UP 15HP MOTOR<br /><br />could be ignition related. after she dies, if you let her cool-off for a while, does she start any easier.<br /><br />YES, IT IS EASIER BUT SOMETIMES DOES NOT START AT ALL...HAD TO USE THE 15HP TWICE TO GET BACK IN, ONCE IN AT DOCK IT STARTED UP.<br /><br />let us know what you find<br />THANKS FOR YOU RESPONSE
