Re: all in one dash instrument
I don't know what comes in the new boats, but I assume this is analog and not a set of digital readouts.<br /><br />If analog, 18rabbit is right. To kill all your gauges there must be some common problem, and the ground is the best spot to start looking. <br /><br />Just look for a common wire/pc board trace that goes to all the gauges - the minus side if they are marked.<br /><br />If these gauges are all on a PC board like auto instrument panels, take a very close look at the board, especially where the wires attach. You might see a hairline crack somewhere. Make sure you look closely - I use a jewelers loupe. If you find one just resolder/repair.<br /><br />Can you describe what you have in a little more detail (analog/digital, mounted on a PC board vs. all wired, etc.)
