all most capsizeing
donnydodad
1984 16.5ft skeeter ss starfire ,1984 yamaha 150 hydro tec V6 motor,
First question is where is the check plug or fill plug for the power trim hydrolic fluild located? Little noise and a little slow,,
2nd question when getting off plane to stop or idle this boat , huge wake follows water came all the way over driver and passeger seats or one third of the boat was covered, had fuel problem! Sorry anyways was told to gas it when wake aproaches the stern of the boat going into idle speed?? Is this mannual jack plate set up wrong? i have owned 2 mark twain run a-bout boats since age 16 and plenty jon boats but this is first bass boat ever, Also due to fuel trouble before i was un able to gas it at time of wake approach,,Not cause im a total noob lol Any help fellows?/? Thank you for all repleys
tashasdaddy
Re: all most capsizeing
it is not unusual to get a stern wake, in a quick stop. Good bilge pump!!! it is a problem with those low slung boats and heavy sterns.
Home Cookin'
Is the 150 too big for that 16' boat? do you have other stuff in the stern (fuel, batteries, you) that can be shifted forward? Although your post was largely unintelligible, it sounds like you have a dangerous set-up.. As you learned, moving away from the stern wake isn't always possible. Also try slowing down more slowly rather than going from full to stop.
Bifflefan
I also have a low stern, I always slow down and then turn around as i am coming to a stop, that way i take the wave at the bow. You just have to take that into account.
donnydodad
Well i am slowing down at a very slow rate, the boat either is on plane or it isn"t , there doesn"t seem to be much of a happy medium, but i well try to move some of the weight forward as advised thank you ..
Home Cookin'
Dealing with stern wake occasionally is part of boating, but neither "huge wake follows water came all the way over driver and passeger seats or one third of the boat was covered" nor having to do a 180 each time you stop is normal; you each have dangerous set-ups. If Biffle is running a racing boat alone, fine, but you can't go carrying victims--I mean, passengers--in a situation like that.
Kev144
Actually, its quite normal for these small speed boats that are low to the water. My Charger DL does the same thing. If you slow down from being on plane, the water can come up and over unless i give it a tiny bit more gas. Love how you imediately jump on endangering lives though.:rolleyes:
