Went out this afternoon, and the boat ran perfectly on the way out, which is about 10 miles one way. On the way back (after traveling about 2 miles), we hit a small wake from another boat - which we slowed down as normal so none of us ended up with broken backs - the boat was surging and wouldn't get over 3500 rpms at wot. I thought something might be up with the prop, but that wasn't the case. Checked all the spark plug wires, and they were all connected properly. So we limped back home at about 3000 rpms, and when I adjusted the trim it did seem to surge a little.
Back home on land, and after cleaning everything up, I pulled the prop and everything looked fine. Had a new thrust washer from a new prop that I never used, so greased the splines up and put that all back together.
I pulled the spark plugs and they did look like they could use a changing, but nothing terribly bad.
Pulled the fuel/water filter, which seemed fine (I've seen worse, which usually causes more problems at idle that I don't have). I did put fresh gas in today, but that doesn't seem to be the issue as the fuel filter was fine.
Checked oil, and that is fine - proper level and looks good.
I just cleaned the flame arrestor about 3 weeks ago, so that shouldn't be a problem.
I checked out the sticky in the adults only, and i'm not sure where to dig into next??? This just seems like it should be a fairly easy fix, but need someones advice on where to look next?
The engine is a 2004 3.0 mercruiser, with the alpha 1.
