hi, i have a 1975 4.5hp mercury outboard.
it had not been used in about 15 years, once i had cleaned and replaced the carb i connected the fuel line and she started. It ran for a good 3 hours or so then spluttered a fair bit and eventually died. It turned out that it wasn't the best idea to use fuel which was 15 years old! So i cleaned the carb again and replaced the fuel pump. I hooked it up again (fresh unleaded fuel/oil) and it will only start with wide open throttle and once it has started it will not tick over it will only rev up high or nothing at all. I tried adjusting the mixture screw but it didnt help.
Is there an idle screw on the carb?
Any ideas as to solving this problem?
thanks in advance Ben
