Re: Alluminum Boat Modification
Ditto. My boat stated life as 50's style runabout that has long since lost its cap. I have since installed 2 bench seats and a casting deck and she's as solid as rock. You may want to brace the sides prior to removing the cap so the hull doesn't flex outward when the cap comes off. Otherwise, you should be fine. Just remember there are a few rules when it comes to tinnies. 1.) No pressure treated wood! Use non-PT plywood and seal it with either epoxy, fiberglass mat & resin, or several coats of Spar Urethane. 2.) Mount all wood using stainless steel hardware and/or aluminum pop rivets dipped in 3M 5200. 3.) Prior to paint, prime with a light coat of Zinc Chromate Self-etching primer, then apply top coat. That's really about it. You can get everything you need except the epoxy and f'glass supplies from Lowes/HD, which does carry Spar Urthane, so you could get everything in one trip, if that's the way you want to go. Good luck. Keep us posted. We love pics
