elkhunter338
- Joined
- Jun 27, 2009
- 818
some of you may remember my winter project was new axles, springs and disc brakes. Well that all seemed to go well but this weekend I took the trailer for 5 mile test pull and found metal in my new oil lube hubs.
What it was from was the Kodiak oil lube hub kits. The alum hub hit the washer behind the wheel bearing nut. The washer is slightly larger than the nut and slightly larger than the inside of the alum. hub. So when I drove the alum. oil lube hub onto the trailer axle hub it pushed into the washer by maybe 1/16 of an inch. Well now I have alum flakes all through my bearings. To replace all the bearings and seals will not be cheap.
I am contacting the place where I bought the axles and oil lube hub kits and hopefully they will send me new bearings and oil lube hub kits (include the seals which are not your run of the mill seal for when you use grease).
To fix the issue all I have to do is grind the washer down alittle bit, then there will be clearance.
Since alum is softer than steel I think the bearings might be ok. In the past I had alot of alum get into a motorcycle engine from a timingchain issue. I fixed the problem and ran the motor cycle for along time until I sold it. All that alum when through the engine bearings, oil pump and such with no failure.
I will see if southwest wheels will send me new bearings and seals.
My outdrive went on alright so I should be ready for the water in that aspect.
Hope others are having better luck getting their rig ready for the summer fishing season.
