Jim Hawkins
- Joined
- Mar 11, 2013
- 506
Yup, almost went to the bottom of the canal from a bilge pump malfunction, here's what happened...
The boat is a 1997 Catamaran by Nautico/Seagull. Inside both hulls are bilge pumps with automatic switches. When one turns on the other does too. They are accessed by two round ports near the stern of the boat. The boat was new to me and I was still learning about the systems including the bilge pumps. When it rained I had to go out and manually operate the pumps with the switch on the console, the automatic switches weren't working.
Trying to figure out the problem I found one pump had a mechanical switch, the other an electronic switch. In the course of fiddling with them the one with the mechanical float switch began to work and as they are 3 wired they can either come on automatically or with a switch on the console. As I said, when one comes on it is wired to turn both on. OK, so here's how it happened. The boat was leaning slightly to one side (the side with the non working switch) and it began to rain. Since the boat was leaning the rainwater naturally ran more to that side. This increased the pressure for water to leak into that side hull...and the boat leaned more, and more. Finally, the upper side hull got enough water in it to operate the pumps BUT since there was less water in that side it quickly pumped that hull dry and left the other still full now with the boat leaning hard and rain coming down in buckets. Now the angle was so steep that all the rainwater ran to the lower side and had only another couple of inches to go before the water started pouring in.
I had been home the whole time and watching it to see how the bilge pumps performed. I looked out and saw the boat sitting what appeared level and no water above the deck. It continued to pour rain and less than 10 minutes later when I looked again I saw the boat leaning so hard over it was ready to sink. I ran out, and getting into the boat on the high side to help level it I turned on the pumps manually and began bailing like a madman. I was at it for about 20 minutes with the rain coming down so hard I could only keep it in check before I finally got it under control.
So, I've been reading and researching bilges and switches and have read that pumps fail far less often than the switches and the switches are almost universally problematic. I'll be posting a thread on my repairs but the gist is, after sealing up the deck to slow water penetration I will install 3 new pumps with automatic switches all switched together. 2 will be in the hulls and the third will be in the center hull. This cat has a very small middle hull that runs half the length of the boat and is only several inches deep and several wide. It also seves as a chase for wiring etc running from the console, under the deck and back to the motor. Instead of sealing this off, I am cutting the deck to open it up to use with a 3rd pump. This will catch all the water from the upper deck before it can get to the outer hulls. And, that 3rd pump will have an additional backup switch.
