littletunny
- Joined
- Apr 2, 2008
- 96
I wish I would have found this board sooner. This is where I started long story short - rebuilt the carbs.
http://forums.iboats.com/showthread.php?t=241828
UPDATE.....
Cleaned the carbs and the motor fired right up.
Here is the problem. It will idle for about a minute or 2 then act like it wants to stall but it doesn't and the motor recovers and the process is repeated. Mind you now this is on the muffs. In the water it probably would have stalled.
Tried the Clymers carb adjustment. It called for lightly seated, then back out 2.75 turns. How do know if the screw is lightly seated? It seems pretty stiff.
Anyway the problem persisted after the Clymer carb adjustment. It wasn't in the water so that moght have affected it.
Another thing, the idle seems fast. I cant measure it but it seems to idle faster than the recommended 725-775 rpm Clymer recommends.
Should I mess with the "idle speed screw" before or after I adjust the carbs?
John, I have read your carb adjustment instructions. Am I the first or second set of instructions? Any other tips appreciated!
Thanks for your help!!!
UPDATE.....
