Puzzled look
- Joined
- Jun 3, 2009
- 36
Hi
Ive been having problems with my engine 1976 Mercury 200 (20 HP). It ran ok but needed about 1/4 choke constantly out to run. Carb problems I thought. So I set about stripping the carb down and found it to be full of crap! I have since cleaned it and replaced every gasket and the float with new ones. Ive put it all back together and started it up. Problem solved the I dont need the choke to run it only to start it!!
The problem now is I cant get it to Idle and when it runs at high revs it keeps missing. What could this be Im a novice so Im really stuck.
Ive adjusted the idle screw but assume this is for fine adjustments and i think i have something bigger on my hands.
The other burning question is there is another screw on my carb on the right hand side What is this?? I have tried to take it out but it is stuck could this be the cause?
