Hi, I have a 2010 Marine Power EFI 5.7L S/B v8. My outdrive is an alpha 1, actually the replacement made by SEI. What I want to do is used a full closed cooling system. However, most full closed cooling systems are made for use with an engine driven pump to draw water from the outdrive or other source. Is there any way to remove the impellor on a Alpha one and let the engine driven pump do the work instead? Or could both be used? When I speak of engine driven pump I mean a the separate pump that would draw water from the outdrive, like in a bravo setup, and not the main water pump on the on the block. Thanks Roman
