GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
I am replacing the bellows connected to my outdrive due to weathering and cracking. I can get to the exhaust bellows just fine but I can't figure out how to change the cable bellow. Thanks in advance for your help. Stuart
From inside the boat remove the plastic tip from the lower shift cable. Remove the clamp <br /> on the end of the bellows. Unscrew the stainless steel tube, and pull the cable out of the <br /> boat through the boot. Pull core out approximately 1' to protect tip. Lubricate and slide<br /> the new cable bellows up the cable.
Trent, sorry it took so long to get back with you, my wife found something else for me to do first, but that worked great. Thanks Again for the help. Stuart
