Dropped lower to change impeller, this is what I found.<br /><br />
<br />Splines almost completely worn.<br /><br />Dropped upper drive to check driven gear splines, guess what I found.<br /><br />
<br /><br />Fishermark had a similar.<br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=010374#000000 <br /><br />The drive only had 50hours, its a brand new SEI drive installed last Sept. Suspect its the shaft breakage tat allowed the gear to float and wear the splines away. Gear splines are ok, hardly any sign of wear, gear should be much harder. <br /><br />Suspect that the condition existed for the 50hrs. Remembered that it made a loud grating noise last year. Stopped when lower drive was removed for bearing change. Noise did not return. Lower drive was later changed due to its housing condition, everthing worked fine throughout the year.<br /><br />Just goes to show what 50hrs can do if something's not right.<br /><br />Work ahead......
<br /><br />Qystan
