I have an 89 maxum 2300sc. I may have more than 1 problem going on so here is some background information. I have been an automotive mechanic for years so I understand the basic operating principles, however I am not a marine mechanic. That being said, basically I know enough to be dangerous. I also have a wife and 3 boys, which means I don't have any money. So any help or advice is greatly appreciated. My boat has a 5.0 mercruiser and an alpha1 drive. The engine seems to run ok for the most part. A little underpowered but it s a 5.0. It does not idle well all of the time. I do not know what the idle speed should be, or what and how to set the timing. It looks like someone walked the wires on the distributor cap.
Part 2 of the problem is that when I put it into gear it clunks fairly loud. It runs good and I see no metal in the lube. I just don't want to tear anything up. I did notice that if the drive is up very far or turned hard over one way or the other I get a little clicking noise. I think it is a u joint but not sure. Knowing that one thing effects another, I'm not sure where to start first. My thought is, wires affect timing, timing affects idle,rpm and power, idle and rpm affects shifting, then "clunk"! Am I right?
