MajBach
- Joined
- Jun 21, 2003
- 564
So I am doing some long overdue maintenance on my engine before putting it in the water ( I know - a little late but I have other toys too). Right now I am replacing the impeller for the first time (first time Ive done it that is). Much to my surprise, I notice that the reservoir in the engine compartment had about a half inch of sludge in the bottom. So, a couple of questions regarding this:
- why are there two wires and some type of sensor in the reservoir (one wire was disconnected - by mistake I think)
- is there a tried and true method of cleaning out the tube leading from the reservoir to the leg and the gear box itself?
- what is the capacity of oil for the gear box
- do you fill it from the reservoir or do you pump it in like with an outboard?\
Thanks
Thanks
