Alpha 1 gearcase pressure test / vacuum test
lenny2113
After replacing water pump impeller, I pressure tested gearcase by pumping air into it through the vent screw openning. It held 15psi for 24 hours. So, I think it's fine. <br /><br />Question: Is vacuum test important? If someone could, please explain why should I do both - vacuum test and pressure test???<br />Thank you. <br /><br />Happy 2004 Boating year to all, <br /><br />Lenny
rattana
Re: Alpha 1 gearcase pressure test / vacuum test
I would think that pressure test pushs the seals in one direction, the vacuum test pulls the seals in the other direction.
crazy charlie
Do both tests Len.Pressure will let you know if it will leak and vacuum will let you know if it will suck up water if it does leak.Charlie
lenny2113
Thanks for the info. <br />I did pressure test myself. <br />How do I do vacuume test? Is there a gauge and a vacuume tool to use? <br /><br />Lenny
lenny2113
I mean vacuum :)
OBJ
Lenny....I got a cheap little auto A/C vacuum tester from NAPA that works just fine. Gauge is built right in. All you need to do is fit a threaded fitting to the hose so it will screw snuggly into the vent hole.
