Re: Alpha 1 Gen 1 for Gen 2 drive
Ayuh,..........<br /><br />Willy,.... I think you'll find that the Alpha 1 Gen. II is compatible with None of it's predecessors,........<br /><br />There's Alot of Interchangeablities between the Pre-Alphas,+ the Alpha 1.........<br /><br />The Only driveshaft Issue I know of is the Shorter shaft for the early In-line motors,.. <br />Rather than the Longer shaft used with the V-motors...............<br /><br />The Longer shaft is used for All of the Merc. drives, besides the In-line motors,.....<br />Matter of fact,.... Even the Bravos use the Same Shaft.................<br /><br />With hearly's 4.3l engine,.................<br />The Input Drive Shaft is the Only part that Is interchangeable with the Alpha 1 Gen. II....................
