kolnerspieler
- Joined
- Mar 16, 2010
- 14
Hey Guys,
I have a problem with my alpha 1 gen 1 outdrive leaking gear lube. I took the outdrive off over winter and before installing it this year I noticed a little gear lube around it. Before I installed it I also replaced the impeller and replaced the small o ring that seals the lower and upper units. I pressure tested the upper part so to say by just blowing into it with a hose on the vent hole and plugging the small oil passage on the bottom and it help air. I put the lower part back on and filled it with oil and noticed that oil is coming from the prop. I took the prop off and can see that the seal behind the prop is not leaking. It looks like the oil is draining down from above somewhere but not sure what the common placed would be to look for a leak. Any help would be appriciated.
