Alpha 1 gen 1 lower unit seal kit?
Clarko1988
I have oil leaking from prop. What and where do i reseal the lower unit tried finding videos and have not found any?
76SeaRay
It might be your prop shaft seals (most likely) or prop shaft bearing carrier seal. I would pull the prop shaft bearing carrier and replace all the seals.
Try this video to see if it helps. Its for a Gen 2 but similar to Gen 1. I do have the lower unit rebuild video's but a bit of overkill for just replacing the seals.
Clarko1988
I need to pull this bearing carrier out but not sure i want to spend 200 on a pull you guys have any ideas on a puller i could use locally
Clarko1988
Heat the outside? Both ends of carrier? All i have is a little propane torch. Im letting it soak in some penitrator.
76SeaRay
I used the same method at Johnkom to get mine out. Careful with the heat, aluminum has a low melting point. Use repeated cycles of heat and cold.
achris
More fish than mountain goat
STOP!
LEAST likely!
Before you go throwing money at the lower housing, oil from the prop might be from the seals at the bottom of the top housing, or it might be the shift shaft seal. Personally, I have replaced about 20 shift shaft seals for every propshaft seal that's leaked.
Do a pressure test and find out where the leak is.... Blindly just replacing seals until it stops leaking is frankly, not clever!
Chris.......
Some resources for you:
Which seal.
How to pressure test
johnkom
I think you will agree this seal was BAD.
76SeaRay
achris has a very good point and a pressure test is really warranted. Even if you replace all the seals you will want to pressure test the new seals. Given the picture of the prop shaft seal, you may need to replace multiple seals.
Rick Stephens
It may very well be just the prop shaft seal. From appearances something wrapped around the shaft and burned the seal up. Pressure test time to prove the theory.
achris
Soo i found the leak and was coming from the shift seals.
Seal. There's only the one. Use the special tool and remove the shift shaft bushing, and replace the complete bushing (it comes with the seal in it).
23-8M0112749 Bushing Assembly
Chris.....
