Christopher87glenn
- Joined
- Jul 10, 2017
- 14
Hi all, thank you in advance for your help. I want to do a full service on my outdrive being that im the new owner of the boat. I have already done u-joints, bellows, gimbal shift cables.. i want to re do the seals on lower unit (weep hole is leaking slowly but leak is a leak) and to want to put in a new pump and impeller.. tracking down the RIGHT kits at the LOWEST cost is grueling and confusing at best.. any links or p/n for the kits i would need would be GREATLY appreciated.. thank you.. outdrive is attached to a 3.0.
