I have a 2000 bayliner Capri 2150 with the 5 liter v8 and alpha 1 gen 2(carborated). I adjusted shift cable as the manual recommends but I still have a clunk noise.
I use the boat for running around in the bay and lakes. When on the lake usually have 5-8 people on board and we wakeboard from the boat also. So there's a good bit of putting the drive in gear and hammering down the throttle. Also have a 4 blade prop for hole shot.
What has been happening: wakeboarder in the water engage drive and WOT. Drive engages then a second or two afterwards there is a thud/clunk. Another issue is I cannot trim the drive up under way much without a good deal of rumbling coming from motor/drive area. As long as I don't trim up no noise. We have checked running the boat on muffs and turning drive all the way left or right no noise.
The second problem, if I have the boat loaded and not many in the bow when I WOT to plane I hear a pre detonation/ping noise. If I accel slowly and have the bow weight proper no ping and I can WOT all day long with no detonation noise.
Any thoughts?
TIA
Any thoughts?
TIA
