At the end of season I had a very very small amount of outdrive lube leaky out of the prop area when the boat was on the trailer. It was about a week after a drain and refil and a cpl hours of use. There was no water in the outdrive. I pulled the outdrive and pressure tested it over 24 hrs and spun the prop several times during the 24 hrs. The pressure never dropped. The outdrive was resealed and water pump installed 2 season ago and I put about 20 hours on it since (total hours 120 ) I checked the prop shaft seal for fishing line etc and there is nothing obstructing it. Any ideas or thoughts ?
