jakwi
- Joined
- Jan 7, 2019
- 184
Hi all, I'm working on my sterndrive and I've found a bit of oil in the bellows, no water, just oil. I assume this is the input shaft seal. Assuming I change the seal, do I need to replace the bellows also? They look to be in good shape, with no cracks at all in any position.
Also if so are the aftermarket bellows kits acceptable, or is this one of those items I should go for the oem parts kit on?
How about the aftermarket gimbal bearings? Are they any good.
Thanks for the help guys
