Boatrunner1
- Joined
- Aug 7, 2018
- 14
Just got a 1995 Larson Escapade 240 with a mercruiser 5.7L alpa 1 gen 2 drive. The gear oil resevoir empties after about 20 minutes at idle. No gear oil in the bildge but a gear oil slick comes from the outdrive into the water. I drained the gear oil out of the drive and got about 3/4 of a quart and it was not milky.
I attemted to do pressure test of the drive while it was still hooked to the boat. I removed the hose from the resevoir and plugged if first before i tried to pressurize the drive. I hooked up the air source to the vent hole and put the screw back into the drain hole before I tried to bring the drive upto 15 psi.
when i applied the air pressure the pressure gage remained on zero and the drive did not pressurizs at all! I could hear the air going into the driveclose to the vent hole where the air feed was hooked upto, but the guage would not come off of zero psi....
The only thing i can think of to get zero pressure with the drive hooked up and the resevoir line plugged is that the hose from drive check valve that goes thru the hull is disconnected or broken.
Next chance i get i will pull the drive off and do a pressure test to see if it will move the pressure guage off of zero psi.
Any thoughts?
Thanks in advance!
Any thoughts?
Thanks in advance!
