Hi, I've got a 1997 merc alpha 1 gen II, with a merc 350. Just noticed quite a large gear oil leak that appears to be coming from what looks like a couple of weep holes on either side of the top of the lower unit. When I raise the outdrive, it appears to leak from around the gear shaft bushing. I suspect that the oil seals just below the water impeller are leaking, but from what I've read on here it seems that I probably should pressure test the stern drive. I've looked through my shop manuals and can't find anything regarding pressure testing. It seems rather simple to pressure test, but I'm confused about a couple of things that I can't find elsewhere on here. My outdrive has the square bottle for gear lube located within the engine compartment. Once I drain the outdrive and start to presure test, won't the pressure just escape through that bottle? Am I supposed to remove the outdrive before presure testing? If so, how do you plug the hole that leads to that plastic square bottle? Also, I'm guessing that I'm probably going to have to pressure test the lower unit sepparately, and possibly the upper unit also, so that I can see where it's specifically leaking from. Again, how do you plug the oil passage that leads to the upper unit, and vise verca?
Also, by the way, I was looking at the service manuals under the Don S link and can't find the proper manuals for 1997 merc 350. It appears that the one I need is #17, but when I try and download that, all I get is the first 6 pages of Book 2 of 2. Does anyone have a link to the full maunal?
Thanks
Thanks
