turbodriven
- Joined
- Jul 13, 2006
- 38
Boat is a 1991 SeaRay with a 3.0l mercruiser and an Alpha 1 outdrive. I believe the outdrive is a Gen. 2.
Stbd. trim hose (the short one on the outside) sprung a leak and it squirts out a small amount of oil when operated. So I'm changing the line. Easy enough.
I tried searching but there seems to be no posts dealing with what to do after this though. So...
1) I'm assuming I'll need to bleed the system of contaminated fluid since water most likely seeped in. Even if just a little. What is the best way to do this? Is is similar to "pumping brakes" and "bleeding brakes" on a car?
2) What kind of "oil" do I need to use?
