Alpha 1 Gen II Water Pump Repair Kit
gjcombs
All,
Now that I know I have a Gen II sterndrive, I want to replace the impeller, gaskets, and seals for the water pump.
The p/n on the impeller is 47-43026. Is this kit an acceptable replacement?
http://www.iboats.com/Water-Pump-Im...e-Outboard-GLM-12042-Sierra/dm/view_id.171969
I am asking because the p/n lists for replacing 47-43026T6, 47-43026T8, 47-43026T11 impellers, but not just plain 47-43026.
If not, please suggest one... :)
TIA
Re: Alpha 1 Gen II Water Pump Repair Kit
Ayuh,... That's for a Gen.II... Should work Just Fine...
gjcombs
Thanks, Bond-o.
Any idea what the T6, T8, T11 tags indicate (in case I run into this with other parts)?
achris
More fish than mountain goat
You're also going to need a pair of alignment pins... Look in the manual.
Chris.......
