alpha 1 grease points hard steering
Jay Curtis
i have a 1993 alpha 1 drive sn OF235939 transom sn OF277191 is there a grease zerk for the top of the OD where it turns
part manual does not show it and i cant find it
and is there any grease zerks on the power steering rack one is shown on the parts list but i cant see it on my boat
having a hard steering problem boat sat for 4 years not sure if its the cable , ps pump or just grease
thanks for the help
Re: alpha 1 grease points hard steering
thanks for the help
Ayuh,.... Odds are it's corrosion where the cable goes through the aluminum tube at the transom,....
The cable has to come outa the tube to clean, 'n grease it,...
Disconnect things, 'n see what moves easily, 'n what don't,....
ktbarrentine
As the years have gone by, Merc has put less and less zerks on the drives and transoms. Are there ANY left now?
Bt Doctur
some ,but the ones I install are the upper swivel bearing ones Merc eliminated. provides grease to the steering arm area and there easy to install without dis-assembly
Jay Curtis
Thanks for the advice guys
Bt Doctur where do you install a grease zerk? and how with out dis assembly? thanks jay
