Alpha 1 outdrive
poppa_4
Can any one tell me if there is a match u-joint to fit the alpha 1 leg...The origanel one is 75832T-1 need one to match it
Bt Doctur
Re: Alpha 1 outdrive
It`s listed as the heavy duty joint, Sierra 18-2174
Ayuh,... I believe there's also a cross-reference up in the Adults Only section, at the top of this forum....
Bt Doctur
click the marine store header , merc engine parts,merc drive parts, page 4
We may do a lot here but you have 2 fingers too
poppa_4
Hey guys I'am back again..picked up u-joint today from the yellow brick road list but it will not fit little to big ....the serial # on my leg is B851398 anyone here know the u-joint number for this leg and then need a match for it...
Bt Doctur
define too big and what part number did you buy. There pressed in not slipped in.
poppa_4
They were to long could not get the clips on them...are these to different u-joints ..75832T-1 ....75832T...
ziggy
if i was doing the job your trying to accomplish and it was giving me grief like your getting. i'd just go get the proper oem part and move on with the project. might spend more, but your level of grief will do down.. the grief level (or lack of)can be worth dollars imho..
maybe ya dropped one roller into the cap??
poppa_4
My trouble is if I buy the proper one I have to wait 2 weeks for it to come ..thats why I'm trying to match one up...
Bt Doctur
I`m sure there acceptable because I use them, You may have jammed a needle roller sideways instaling them, ask me how I know.First I remove the cups and grease then making sure all the needles are in place. I insert the cross first, press 1 cup in first to the snapring groove, slide the cross into that cup, install 2nd cup presing in untill the snap ring.Its VERY EASY to dislodge a needle and jam the cup.
