alpha 1 prop removal question
fmalott
i pulled the prop off so i can drop the outdrive to repair bellows and gimbal bearing and to replace impeller when i drained the gear oil it was very clean meaning no water so i don't need to replace the gear seals but when i pulled the prop off i grabed the shaft and i can pull it in and out about 1/16" to 1/8" is this normal distance
achris
More fish than mountain goat
Re: alpha 1 prop removal question
+1... normal
