Alpha 1 sterndrive Oil Seal
langford7
I have a 1984 Del Magic,470 & Alpha 1 Drive. I removed the lower end of the Sterndrive to change the water pump. When I went to re-install the lower end I noticed that the upper oil seal is bad. Can I just remove it from the bottom? It looks like there is a cup that holds the oil seal in. Is this true, can I pull It from the bottom?
Any help would be greatly appreciated!!!!!!!
Thanks,
Billy
ziggy
Re: Alpha 1 sterndrive Oil Seal
there's 2 oil seals. the lower one can be removed and replaced from the outside. the upper one requires full disassembly of the upper to replace.......
langford7
Is there a retainer that holds the outside seal and does it require a special tool to remove it (the retainer)?
Thanks again,
Billy
ziggy
no retainer. just friction + locktite 27131. mercruiser part number, 92-809820....
on my 1 drive i used a seal puller ya can get at any autoparts store. i just used a socket to drive in the new one. there is a special driver to put it in though.
sounds like you need a service manual.
check this thread out.... #6 is for your drive. confirm proper service manual by serial number.... http://forums.iboats.com/showthread.php?t=251571
the service manual has all the facts in it for you.....
langford7
Got it!! Thanks for the help Ziggy. Now it's time to dive in to the heat exchanger. Tube leaks, fun, fun!!
Thanks again,
Billy
