I have the prestolite high volume low pressure pump. It has the manual release valve on the bottom and 2 lines.
1) What is the real part number for this and what part number for the cap and brushes?
2) If I buy an oildyne unit, will it plug and play or will it need to be adapted?
3) Different topic but have an old #1 drive for a spare. The prop nut threads are course not fine. It has a roughly 1/4" spacer built into the shaft. Using the original bushing does not work with newer props. I bought the spacer and washer per the manual and it is still to long. The 1/4 inch spacer looks like it is part of the shaft. Is it or do I need a different adapter?
Thanks
Todd
Thanks
Todd
