Sea Gullible
- Joined
- Nov 21, 2005
- 10
I have an Alpha 1, 350 Merc, 22 ft boat.<br /><br />When I put her in reverse, the outdrive thumps repeatedly and firmly as if it is not all the way in gear. She does move in reverse so the prop is turning. <br /><br />When I do shift into reverse, I swear it pops in as it sounds similar to the forward shift which works fine. If I am not in the water, running from hose, the thumbing is not as serious but I can still feel it vibrating the boat.<br /><br />It was doing this before and after I put in a new lower shift cable. I understand I may need some practice and experience to properly adjust the cable but wondered what else this issue could be in case a proper adjustment didnt work. Clutch dog, reverse gear, etc?<br /><br />Thanks!<br /><br />SG
