alpha drive/gimbal removal help needed
skinny1965
ok due to haveing a rotten transom in my glass boat I must remove my outdrive from transom
I have removed the drive from the gimbal that was simple. the next is the gimbal stuff and my questions
do I have to disassemble the gimbal to remove it and the housing or can it be removed as a assembly and what do i need to watch for
this unit has had a rebuild in the last year and not really used so i hope to not wreck or disturb very much
Re: alpha drive/gimbal removal help needed
Ayuh,.... Now ya pull the motor,....
Then the exhaust pipe,....
Then the inner transom plate,....
Then push the transom housin', Complete with all the gimbel ring/ housin', off the hull,....
achris
More fish than mountain goat
The gimbal housing comes off as an assembly
You need to pull it off square. If you **** it off any, the studs will bind and it will not move.
Once the drive is off and the engine out of the boat you will need to remove the steering cable, exhaust pipe and the trim pump from the inner transom plate. Then remove the lowest studs from the bottom of the housing, they ate the ones with the anodes on the end. Then, working from the inside of the boat, remove 2 screws from just below the steering lever, and 2 nuts halfway down between the screws you just removed and the studs at the bottom. Once they are all removed you should be able to slide the inner transom plate off, then push the gimbal housing out of the transom (have someone catch it on the other side :)).....
skinny1965
thank you that is just what I needed
can someone tell me over all thickness the transom should be
flipbro
2 inchs min. 2 1/4 inch Max
BigDog98
To access the gimbals housing without taking it apart you will need to pull the engine and access the bolts from the inside if the boat which will then allow you to pull of the gimbals unit with ease. But first you will need to take off your steering rack.
