Alpha Drive Leak
ricksi
I have a steady stream of water coming through my Alpha One outdrive. It's a small stream, just beyond a drip. It is centered on the bottom metal cavity directly under the trim hoses . I recently installed a new engine and decided to install a Mercathode system. I was convinced it was the cause of the leak given it's location. It has a built in seal, I inspected and reassembled it paying close attention to the torque specs. I still had the leak, so I tried again this time using RTV. I even filled the hole where the wires go through, but no success. I replaced the Y pipe a few years ago and inspected it when the engine was out, so I don't think it's the source. Anyone have any ideas?
Re: Alpha Drive Leak
Those built in seals where yer mercathide wires run thru are irreplaceable I've seen those fail..they come with zinc that bolts to the mercathode and there's also a gaskets there
Ayuh,... As ya know, there ain't no Easy Button for dealing with this stuff,...
And,...
the only way to find a leak is, LOOK...
Maybe using a mirror, or camera might help...
ricksi
Believe me, I have become a contortionist trying to pinpoint the exact point. My wife had to pull me out of the bilge by my ankles. With a light and mirror I can see that it's coming from under the hoses but between the Y pipe, the hoses, and the flywheel housing, that's as close as I can get.
ricksi
I just did and it's leaking from the transom plate. I reached in to see if the lower transom bolts were tight and the first of the 2 lower bolts turned easily and came right out. The bolt is tapered as if it went through a pencil sharpener. I suspect the others are not much better. Maybe there's a dissimilar metal issue, but it seems like those bolts should have been stainless steel. How bad is the news? Can I change them without removing the motor?
Pete104
Maybe! If they are very bottom ones, yes. You have get the other half out & as flexible as you seem to be, put the new ones in. Good luck!
ricksi
I'm trying to talk my cat into doing it.
Pete104
Purr-fect job for a cat! (kidding)
Just so you know, you are up against " transon issues". Moisture got to those bolts somehow. They are only made of aluminum & deteriorate pretty quick once they are wet. Anything new is better than what you have now!
Ayuh,... The Bad news is, Yes, ya Gotta pull the motor...
Those are the anode stud/ bolts...
Their aluminum...
Ya need to put the Right 1s back in...
Like Pete says, ya gotta find the leak,... Those bolts should be reasonably dry...
A wet transom can really be BAD news...
ricksi
When I installed the Mercathode, I was instructed to throw the anodes away and screw on plastic caps. Since I no longer need the zinc protection, can't I just use stainless steel bolts?
