alpha first gen trim position
tswiczko
drive goes up and down. Does not stop on own limits started looking and found cracked and broken wires on trim position switches. can these be by-passed and run by manually stopping or am I going to be spending a lot more money on parts.(1989 alpha 1 gen one 350 magnum 270 hp.)I know for safeties sake this should be replaced and is there a less expensive alternative.
Thanks in advance I have found your knowledge, resources and advice invaluable in making boating safer and more affordable.
Re: alpha first gen trim position
Ayuh,... I never even installed the limter, or the sender on my boat....
Sounds like your's has already been by-passed inside the boat,... 'cause it Works...;)
When starting or on the trailer, or Maybe when puttin' at idle,.. You have to be Careful...
Once At Speed,... There's No way to over-trim without Blowing out the prop....
