Alpha g2 zinc on bearing carrier,mercathode?
telstar1
Just realized a G2 drive has a zinc on bearing carrier in behind prop. Mine's gone of course,Merc dealer says he never gets requests for them. What is the deal? Do most people use them or not? Cant see evidence of corrosion in that area.
Also, thinking of getting a Mercathode system.Anyone have comment? Will it reduce or eliminate the usage of zincs?Ive never even seen one on aboat so have nothing to go on.
Re: Alpha g2 zinc on bearing carrier,mercathode?
Zinc's are used as sacrificial metals and are there to protect the drive exposed to electrical currents due to bad or non-existent grounds. The Mercathode systems is installed to make your boat less attractive so to speak to stray electric currents from other systems. Boat (A) could have a perfect electrical system but may be damaged by boat (B) which has a bad ground system. A boat which has been fine for many years with no effects due to stray currents may need to have additional zincs or additional anodes from a Mercathode if metals are changed. Changing from a aluminum prop to a stainless steel will increase the attraction to currents.
My single bravo 3 (stainless steel props) showed signs on the drive housing behind the props every year when I pulled it out for the season. The marina is a modern setup but new zincs and repainting didn't help much. Using the Mercury prob and a digital meter I determined the field current being transmitted by my Mercathode was not sufficient. I installed additional Mercathode and 2 additional anodes, field current was increased and the problem stopped.
If a boat is in the water but not plugged into shore power, if a boat is kept on a trailer except when in use, then you probably can get by without need for additional zinc's or a Mercathode.
Don S
You shouldn't be using Zinc anodes in salt water you should be using aluminum anodes. The "Mercruser" OEM lot #888756A1 includes that anode in it.
