bullsnot
- Joined
- Aug 22, 2012
- 60
Looking for an education on these alpha drives. I just completed an OMC to Alpha stern drive conversion. The drive hasn't even dipped a toe in the water yet. Just finished installing yesterday.
I followed the instructions to the letter when adjusting the shift cable. The very last step was to install the prop. While installing the prop I had it locked in reverse.
Now when I fire up the boat and test the shifting it seems like it wants to jump out of reverse. When I try to lock it in reverse with the engine off you don't have to try very hard and you can push the prop and get it to jump. This isn't a cable adjustment issue as I took the cable off and tried it manually with a helper.
Is my brand spanking new lower bad? Is it possible to round off the clutch dogs just by tightening a prop nut to 55 lbs?
