Alpha Gen 2 Power Steering Leak : (
bryank75
Hey Guys,
Well my little 4.3 Alpha Gen 2 Mercruiser LX is leaking powersteering fluid, if I top off the pump to full, it will go down in about 2 hrs of boating. Do you think it is-
1. The Ram-steering actuator?
2. A hose, either return or powerside?
3. The pump? I have visually looked very hard at the pump and can't see any leaks.
My hunch is its the Ram. If it is, I am seeing them on Ebay and used ones are about 90 and rebuilds/reseals are 120-140...
Any help will be appreciated!
Bryan
Bt Doctur
Re: Alpha Gen 2 Power Steering Leak : (
does it appear in the bilge, ? Yes=easy to find
No, I`d suspect the power steering cooler is leaking.
bryank75
Yes it does appear in the bilge, and some will drip out when I remove the brass bilge drain. What do you think?
bryank75
Surely someone can point me in the right direction..
ziggy
wipe everything clean.
remember, fluids run down hill. never up hill..
once ya got a general idea where it's coming from. if ya still can't find it (like i couldn't find a leak once). i put flour or the likes on my most suspicious area of where i thought the leak was coming from. the flour gets wet where the leak is..
i also like to take digital pics of the offending area if i can't locate a issue sometimes. i can hold my camera in places that i can't see. snap off a few random shots and put them on yer computer. look for the leak in the comfort of your home..
best i can do for ya.
