Hello. My Alpha Gen 2 stalls going out of gear into neutral. Shifting into gear is smooth and normal. The lower cable has been replaced. Upper and lower cable adjustment is correct and been done a few times to verify that its right. Lower cable shifts the drive easily and smoothly by hand. The shift assist seems strong in both directions and the interrupt switch plate moves freely. Could the spring for the interrupt plate be weak? The engine is a 1997 model year 5.7 2bbl. Don't have the serial available, but I believe its a 0K..... number.
