silver_power
- Joined
- Jul 8, 2009
- 327
Hello, I have a 350 mag mpi (1A348183) with alpha genii drive. I just want to answer if anyone has relocated the genii cool fuel module as it is at the most difficult to reach position of the engine while one boat. As I have a fpr problem and need change, I can certainly tell that I prefer to pull the engine of the boat than try get myself in there to change the fpr or if is nesecary at the future the fuel pump or the cool fuel module which has already some signs of corrosion. I finally managed to take off the fpr but it was absolutely a pain in the ass......
Anyway As far as I saw, all it need is extensions for 1)the fuel hose goes to pump, 2)fuel hose return from the fpr, 3) water hose inlet to cooler, 4) water hose outlet of the cooler 5)fuel hose to the rail. It would be perfect if the cooler was at different position. We could also had a cut off vane to the return fuel line for test the pressure can give the fuel pump, or /and an adjustable fuel pressure regulator for to have always the correct according to specs fuel pressure and generally everything would be more easy and cheap to inspect and maintain.....
Has anybody made something like that?
As I am waiting the new fuel pressure regulator, my only thought is how I will get back in there to install the new fpr and reassembly everything again.....
